Rear shock brackets
- Jutwit
12 years 9 months ago #104211
by Jutwit
Rear shock brackets was created by Jutwit
I've been looking at these in the store and was wondering if they would be suitable for my jimny with standard suspension? It looks like they will lift the shock a bit, would this be a problem? Or do the brackets only break if you knock them? If that's the case would it be better to get the guards ?
- idiotmobil
12 years 9 months ago #104212
by idiotmobil
Replied by idiotmobil on topic Rear shock brackets
guards are useless just bend up best to just drill out the hole and bolt right through
- Jutwit
12 years 9 months ago #104214
by Jutwit
Replied by Jutwit on topic Rear shock brackets
So the bolts are the issue then?
12 years 9 months ago #104256
by robs5230
standard jimny - for now
Replied by robs5230 on topic Rear shock brackets
not entirely. the shocks on a standard jimny rear mount on the bottom bolt at an angle. over time this can stress the bolt and they snap off. this is much more likely to happen on a lifted jimny. the angle will be magnified and when lifted they are generally used off road. offroading also does expose the lower mounting bracket to a lot of knocks and pressure from the shocks as they soak up the bumps. they can break.
if you have no lift you shouldn't need the shock relocation brackets
The following user(s) said Thank You: Jutwit
- Jutwit
12 years 9 months ago #104259
by Jutwit
Cheers guys, will leave as they are for now
