Brake drum removal
  • Leathery1
09 Feb 2014 11:08 #103956 by Leathery1
Brake drum removal was created by Leathery1
I am probably being a bit thick here, but are there any tips to removing the rear brake drums? The brake light on the dash has stated coming on whenever I brake, think it is low pads. I have just dropped one of the wheel off and cant see anything retaining the drum but it wont budge. Any advice?
09 Feb 2014 11:14 #103958 by mlines
Replied by mlines on topic Re:Brake drum removal
You need to wind back the adjusters. There should be s hole in the backing plate usually covered with a bung. Inse rt a flat blade screw driver and wind them back. Then you can use a m8 bolt to wind the drum off using the special threaded holes in the drum front
Sent from my Nexus 5 using Tapatalk
The following user(s) said Thank You: Leathery1
  • jonesyba420
09 Feb 2014 11:15 #103959 by jonesyba420
Replied by jonesyba420 on topic Brake drum removal
Theres 2 bolt holes in the front of the drum,find some bolts that fit and slowly wind them in evenly this will push the drum off.
  • jonesyba420
09 Feb 2014 11:17 #103960 by jonesyba420
Didnt know about that bit Martin,just pushed mine off with bolts in the front.
09 Feb 2014 11:56 #103968 by facade
Replied by facade on topic Brake drum removal
You only need back off the adjusters if there is a lip worn into the drum.
If there is, and you don't, the drum comes off with a BANG and you will have pulled the retaining pins through the little spring caps.
You can then hammer the spring caps back into shape if you don't have new ones ;)
  • RichiesJimny
09 Feb 2014 12:04 #103970 by RichiesJimny
Replied by RichiesJimny on topic Brake drum removal
If its the brake warning light that's coming on check the brake fluid level.
Time to create page: 0.108 seconds
