!!!!!AIR CON!!!! DRAMA
- Millzy
03 Feb 2014 08:16 #103156
by Millzy
!!!!!AIR CON!!!! DRAMA was created by Millzy
Hey guys I noticed today my aircon starts off blowing cold air but then for some unseen reason just starts blowing normal air like it would if the aircon was switched on and fan just on... And decides when wants come back on and off !! Any thoughts or experience with the problems be helpful thank you
03 Feb 2014 08:57 #103159
by Obarno
Replied by Obarno on topic !!!!!AIR CON!!!! DRAMA
Well that's interesting as mine does exactly the same! I find that if I put it on recirc, rather than on fresh air it helps. I I wonder if it's a problem with the temperature sensor inside the heater unit, or is it simply that the unit is a bit small?
- Millzy
03 Feb 2014 09:32 #103162
by Millzy
Replied by Millzy on topic !!!!!AIR CON!!!! DRAMA
hey mate yeah mine is on recirc all the time that's when does it but I dunno i thought just taking it in for service and regas might fix problem but just didn't wanna spend that money if that wasn't what was wrong
- markyp2000
03 Feb 2014 10:48 #103164
by markyp2000
Replied by markyp2000 on topic !!!!!AIR CON!!!! DRAMA
You should never run an aircon on recirc all the time as it drys the air out and can make you ill my air con also cuts in and out due to the pressure in the system rising as the gas gets hot i just leave mine on wether i want hot or cold air
- barnes
03 Feb 2014 12:57 #103172
by barnes
Replied by barnes on topic !!!!!AIR CON!!!! DRAMA
System is going out on low pressure a protection device to protect the compressor from running with no refrigerant and causing the compressor to eventually seize get it pressure tested and evacuated and recharged.. probs passing from the shaft seal if it hasnt been used in some time
- RichiesJimny
03 Feb 2014 13:02 #103175
by RichiesJimny
Replied by RichiesJimny on topic !!!!!AIR CON!!!! DRAMA
The first thing to do is get the system regassed but also make sure the electric cooling is working when you switch the air conditioning on.
Time to create page: 0.094 seconds
