Top off-road modification!
12 years 9 months ago #103054
Top off-road modification! was created by mlines
Whenever I take the Jimny off-road I have to have the internal fans on to stop the car steaming up which it does at every opportunity! The trouble is this means you get a face full of dried leaves, twigs and dust from the face vents.
Even with a Jimny that is used only on road, it is an embarrassment to switch the fans on and cover yourself and passengers with leaves, dust and pollen.
Well, Suzuki did cater for a filter, they just never fitted it to most UK Suzukis, everything is there apart from the filter. So here is how to fit one......
www.bigjimny.com/images/documents/fittin...or_pollen_filter.pdf
- 410shotgun
12 years 9 months ago - 12 years 9 months ago #103059
by 410shotgun
Replied by 410shotgun on topic Top off-road modification!
I was looking at this the other day under the dash
and took the cover off and got a filter to fit it
Last edit: 12 years 9 months ago by 410shotgun.
12 years 9 months ago #103062
by robs5230
standard jimny - for now
Replied by robs5230 on topic Top off-road modification!
now i don't want to use the face vents
- Tadpole
12 years 9 months ago #103073
by Tadpole
Replied by Tadpole on topic Top off-road modification!
When I changed mine soon after purchasing the Jimny I found the previous owner had marked the removable cover at one end.
I'm not sure if there is a 'right/left' hand to the cover but it all went back smoothly.
I changed mine in August so the plastic did give a little.
Thanks for posting Martin ....
12 years 9 months ago #103123
by Obarno
Replied by Obarno on topic Top off-road modification!
Very interesting - does it apply to all model years? I have a 2007 Jimny.
- 410shotgun
12 years 9 months ago #103152
by 410shotgun
like under the dash by the glove box and you should see a cover around 30mm wide and 200mm long it behind that got a filter for £9 AMC SC9507 part no
Time to create page: 0.122 seconds
