rubber gaiter on front propshaft
02 Feb 2014 15:51 #103030 by robs5230
just had a crawl under the jim and noticed a bit of grease splattered around the rubber gaiter towards the rear of the front propshaft. ( well i think thats where it was i was underneath on my back ) . what is the purpose of the gaiter and is it a serviceable/replaceable part ? as it looks sort of shafted.
cheers
standard jimny - for now
  • GuardianAngel
02 Feb 2014 17:36 #103040 by GuardianAngel
Replied by GuardianAngel on topic rubber gaiter on front propshaft
I replaced mine recently using a universal stretchy steering rack boot that you can cut to size. It's is bigger than the standard one but it still clears the chassis cross member no problem.
All it does is stop crap getting in the splines between the two halves of the prop. It's in two parts. Make sure you line up the UJ's if you separate them. There are two small marks on both halves that you use to align them.
02 Feb 2014 17:39 #103042 by robs5230
cheers. seems the rear end of the boot is shot but managed to zip tie it back on for the minute. out laning tomorrow and wednesday so i'll sort it out next weekend. rob
  • GuardianAngel
02 Feb 2014 18:06 #103046 by GuardianAngel
This is the exact one I got from eBay.
www.ebay.com/itm/200957785086
02 Feb 2014 19:08 #103063 by robs5230
thanks. how exactly do you replace the boot ???
  • GuardianAngel
02 Feb 2014 19:19 #103064 by GuardianAngel
Take the prop down. Pull the two halfs apart and remove the old gaitor. Trim the boot at both ends, and slide onto one of the shafts, then slide the other half on, aligning the two marks (one is on the end of the splined shaft, it's quite small and you will probably need to clean off the old grease to see it).
I smeared the inside of the boot with red grease (suitable for rubber as it does not cause it to swell) just to keep it supple. I lightly greased the splines but don't put too much on as it will be difficult to slide the two together.
Then put the cable ties on (I used beefier ones than the one that cam with the boot), and put the prop back up and bolt onto the flanges.
Time to create page: 0.094 seconds
