rear bumper , any suggestions ?????????????
02 Feb 2014 13:36 #103026 by robs5230
my jimny has a front winch bumper and this 'orrible stainless rear bumper. has anyone made their own rear bumper ?? looking for a bit of inspiration . cheers
[IMG
standard jimny - for now
  • Marmota
06 Feb 2014 22:44 #103731 by Marmota
Replied by Marmota on topic rear bumper , any suggestions ?????????????
Hi
Maybe this will give you an idea for a simple clean cut design for your rear bumper ;) .... and cheap withal :whistle:
In the pics you can see it's kind of "naked", unfinished, but with your "corner bumper" I think will fit great.
Also great way locating strong towing point.
06 Feb 2014 23:01 #103734 by robs5230
i initially thought of channel . what size channel and thickness have you used ? i'm now thinking of box section as it may weigh less. i'm not sure my rear chassis rail ends are standard. looks like someone may have capped them off to fit the 'orrible affair i have on the rear of mine
  • Marmota
06 Feb 2014 23:27 #103735 by Marmota
robs5230 wrote: i initially thought of channel . what size channel and thickness have you used ? i'm now thinking of box section as it may weigh less. i'm not sure my rear chassis rail ends are standard. looks like someone may have capped them off to fit the 'orrible affair i have on the rear of mine
it's not my jimny... it's just a project found on the net and I wanna do it to my rig in the future too.
about the thicknes I wanna use 3mm... and channel size don't know, depends on preference but from what I can tell from the pics (comparing with the plate) I think is about 100mm "U" profile.
if weight is a problem (and I know it is :lol: ) you can try using 2mm metal sheet and weld the channel yourself... or just use aluminium (but keep the two steel box mounts to the chassis so you can still have strong points for towing)
hope this helps
Time to create page: 0.104 seconds
