Metallic Rattle
- lukeyblunt
12 years 9 months ago #102848
by lukeyblunt
Metallic Rattle was created by lukeyblunt
Hi All,
Went out yesterday.. and halfway down the high street, I realised a metallic, hollow sounding rattle when I turned the music down.
It sounds a little like I'm dragging an aluminium chain. :blink: .. Of course, I pulled over and checked it over.. but there was nothing blindingly obvious.
I jacked it up today and span a wheel, and it made the same sound, but slower.
I'm no mechanic but I'm assuming it's something to do with the drive shaft…?
Any other ideas..? Also, what's the fix likely to be..? And why's it done this? - I don't want it happening again!
Cheers,
Luke
Cheers,
Luke
12 years 9 months ago #102849
by robs5230
- lukeyblunt
12 years 9 months ago #102858
by lukeyblunt
Replied by lukeyblunt on topic Metallic Rattle
Is it just a case of cleaning them..? What are they? What do they do..? :blink:
Can't afford all these repairs! :pinch:
- GuardianAngel
12 years 9 months ago #102859
by GuardianAngel
The hubs on front wheels.
Get an E10 torx socket and unbolt them, and the hub will just come off. Then check that its clean inside and the sleeve that goes over the drive shaft moves freely in and out.
Then just bolt back on. Might be worth putting some sealant on the mating surfaces to keep the water out. Oh and a little bit of fresh grease on the sleeve as well.
Replied by GuardianAngel on topic Metallic Rattle
lukeyblunt wrote: Is it just a case of cleaning them..? What are they? What do they do..? :blink:
- lukeyblunt
12 years 9 months ago #102860
by lukeyblunt
Thanks for your response, chaps.
It's not the front wheels. I've jacked up the front and spun them and they don't make the sound.
It's only the back ones, and it sounds like it's coming from the drive shaft..?
Not a clue.
Not a clue.
- GuardianAngel
12 years 9 months ago #102862
by GuardianAngel
Ok so it could be a knackered shaft but it's normally the fronts that go on a J.
Have you definitely got oil in the rear diff?
Check the back of the rear wheel to see if there is any leaks, it could be a sign that your wheel bearings are shot.
Do both wheels make the noise or just one side?
Replied by GuardianAngel on topic Re:Re: Metallic Rattle
lukeyblunt wrote: Thanks for your response, chaps.
Not a clue.
Time to create page: 0.117 seconds
