springs
- 410shotgun
and is there a left and right spring
- DonegalGuy
- 410shotgun
- Venter
L/R springs are usually different, as right hand drive Jimnys are heavier on the drivers side. So either get the firmer or longer spring for the right, or if using same springs, you can but a spacer to compensate for the lean. Check the BigJimny shop, not sure if you can buy it there, but the spacers and different springs are available at the other 3 well known Jimny shops
when you have jimny lean, the front rhs will be lower and correspondingly this will make the rear lhs higher ( making it look like the drivers side rear spring is shot ).Venter wrote: Not sure about hardtop/softtop, but can answer on the left/right:
the spacer corrects the front rhs . the back will even out of its own accord
standard jimny - for now
