changing front axle on jimny?
  • chrisharman
29 Jan 2014 14:42 #102513 by chrisharman
changing front axle on jimny? was created by chrisharman
My front axle has seen better days,had a good quote for a good second hand one.
Just wondering how hard are they to swap?mines a. 2000 model jlx non abs.
Thanks
  • Basketcase
29 Jan 2014 15:15 #102514 by Basketcase
Replied by Basketcase on topic changing front axle on jimny?
I've never done it but it doesn't look hard. Looks like you just need to disconnect prop, the brake lines and the airlines for the front hubs then the shockers and it's off
  • markyp2000
29 Jan 2014 22:17 #102575 by markyp2000
Replied by markyp2000 on topic changing front axle on jimny?
Think i did mine in about 4 hours but then i new all the bolts would come out
  • deedar
30 Jan 2014 00:04 #102585 by deedar
Replied by deedar on topic changing front axle on jimny?
Did mine in about same time too
30 Jan 2014 08:12 #102588 by kirkynut
In theory it's not a tricky job, just a bit big and rusted bolts will need grinding off, so get on the Bigjimny shop and order up radius arm bolts and bottom shock bolts.
You can leave the shocks hanging from their top mounts and the brake calipers can be tied up so you don't have to disturb the hydraulics.
  • markyp2000
30 Jan 2014 13:28 #102602 by markyp2000
Why does the hole lot need changing what parts are shot that need replacing
Time to create page: 0.105 seconds
