Body lifting a Jimmy
  • pmarsh
28 Jan 2014 06:21 #102339 by pmarsh
Body lifting a Jimmy was created by pmarsh
Hi guys,
This is my first post here. I dont actually have a jimny yet but i am in the market for one.
I am looking at a jimny at the moment that has a 2" suspension lift and 30x9.5.15 Kumho KL71s. I have no idea why the guy who owns it at the moment put such big tyres on it. He tells me that it doesnt rub on the guards at all, but he has never taken it off road. So i am pretty sure it is gonna rub like crazy offroad. My plan is to do a 2" body lift once i get it to stop the rubbing.
My question is- once i have a 2" suspension and a 2" body lift will i need extended brake lines, adjustable panhard arms and a steering dampener? Or does the body lift not effect those things?
Cheers in advance
Patrick
  • ChrisM
28 Jan 2014 12:34 #102367 by ChrisM
Replied by ChrisM on topic Body lifting a Jimmy
Doing a body lift wont make any difference to the panard rods operation so if its ok now then there will be no difference.
The steering damper is probably advisable with the bigger tyres fitted.
Not sure about the extended brake lines for the body lift, but if you are planning to take it offroad properly then you will want to disconnect the anti-roll bar to give better travel on the axle at which point you will definitely need longer brake lines.
  • jonesyba420
28 Jan 2014 13:15 #102372 by jonesyba420
Replied by jonesyba420 on topic Body lifting a Jimmy
id think you should have extended brake lines on a 2" suspension lift.
the steering damper will only HIDE the wobble not cure the fault.
id give it a good flex test and see if and where it rubs before doing a body lift as you may not need it.
  • Alliston
28 Jan 2014 13:18 #102374 by Alliston
Replied by Alliston on topic Re:Body lifting a Jimmy
U don't need extended break lines unless u plan to go off road and take the anti roll bar off
Sent from my C6903 using Tapatalk
  • jonesyba420
28 Jan 2014 13:22 #102376 by jonesyba420
Replied by jonesyba420 on topic Re:Body lifting a Jimmy
dunno why you'd lift it if your not going offroad :whistle:
  • Alliston
28 Jan 2014 14:50 #102382 by Alliston
jonesyba420 wrote: dunno why you'd lift it if your not going offroad :whistle:
some people just want to make it look aggressive but don't do off road pointless if u ask me like but that's what some people like to do
Time to create page: 0.095 seconds
