cam sensor leak?
  • Mick C
12 years 9 months ago - 12 years 9 months ago #102226 by Mick C
cam sensor leak? was created by Mick C
G13bb rag top. Seem to have an oil leak from the back of the head. The rocker gasket has been changed and the cam sensor housing has had some fresh sealant on. The cam sensor is now the suspect - can the sensor itself leak, ie leak through the sensor? - if so I'm guessing it's new sensor time.
Last edit: 12 years 9 months ago by Mick C.
12 years 9 months ago #102229 by j999pre
Replied by j999pre on topic cam sensor leak
Try re sealing sensor housing. Is the housing cracked? Getty a mirror and torch have a good look. A lot of g13bb engines seem too leak, sometimes head gasket but yours has just been done hasn't it?
Grey pick up Jimny
  • Mick C
12 years 9 months ago #102274 by Mick C
Replied by Mick C on topic cam sensor leak
Yes James, the head gasket has just been changed - sorted the initial problem but now I've got this annoying oil leak. It seems to be coming from higher up the back of the head rather than the gasketed surface.
  • idiotmobil
12 years 9 months ago #102287 by idiotmobil
Replied by idiotmobil on topic cam sensor leak
theres a round plate on the back of mine about 4 inch round that has a o ring sealing it up and two 10mm bolts fixing the plate mine was leaking from there and the o ring was f%$ked toke out replaced oring and hasn't leaked since
  • Mick C
12 years 9 months ago #102289 by Mick C
idiotmobil wrote: theres a round plate on the back of mine about 4 inch round that has a o ring sealing it up and two 10mm bolts fixing the plate mine was leaking from there and the o ring was f%$ked toke out replaced oring and hasn't leaked since
Thanks mate, I'll check that out.
  • idiotmobil
12 years 9 months ago - 12 years 9 months ago #102290 by idiotmobil
toke me ages to not find it till some else pointed the problem out on here such a simple thing toke ages to sort
but come to think of it I mite have had a water leak not oil leak lol I cant remember
Last edit: 12 years 9 months ago by idiotmobil.
Time to create page: 0.088 seconds
