Body Mounting Bolts
- Iansea
25 Jan 2014 20:17 #102042
by Iansea
Body Mounting Bolts was created by Iansea
When I bought my Jimny it was 'blessed' with chrome bars along the sills. I wasn't really keen on these as they don't stick out enough to be used as side steps, they're not really robust enough to be tree sliders and they make it more difficult to get underneath the vehicle as they stick down a couple of inches below the sills.
After two and a half years of ownership I finally got around to removing them. One side came off ok but when I came to do the other side the nut on the body mount just behind the door, which is used as the rear mount for the bar, rounded off.
Does anyone know the thread size and pitch for the body mount bolts so I can get a new nut without having to make the trek to a Suzuki dealer? I should then be able to use a nut splitter to crack the old nut off.
Cheers
Ian
Cheers
Ian
- Yellostreak
26 Jan 2014 09:57 #102105
by Yellostreak
Replied by Yellostreak on topic Body Mounting Bolts
they are Metric Fine pitch.. just be aware that the ones at the rear of the side steps are larger than the front.. you have to keep spraying them with WD-40 or similar as they are a sod to undo..
- Bits4Vits
27 Jan 2014 05:55 #102207
by Bits4Vits
Replied by Bits4Vits on topic Body Mounting Bolts
10mm -
www.bits4vits.co.uk/store/nuts-39-n-39-b...c-fine/prod_137.html
12mm - www.bits4vits.co.uk/store/nuts-39-n-39-b...c-fine/prod_136.html
If you can't source them locally
Dave
Dave
Time to create page: 0.081 seconds
