Brake warning light
- rexthecat
12 years 9 months ago #101896
by rexthecat
Brake warning light was created by rexthecat
My warning light is coming on, the brakes do need doing so I'm guessing its that though not had chance to look at the fluid levels. If the level is low am I OK to top it up untill I can get the brakes done? If so what is the fluid, dot 3?
Cheers
Cheers
- markyp2000
12 years 9 months ago #101897
by markyp2000
Replied by markyp2000 on topic Brake warning light
Its dot 4 and its yours and other peoples lives you taking into your own hands by negleting your brakes knowing that thay need doing just do then or dont drive it
- GuardianAngel
12 years 9 months ago #101898
by GuardianAngel
Replied by GuardianAngel on topic Brake warning light
If you have a leak then any emergency stop could cause a catastrophic failure like a burst pipe. So I would take it off the road and fix the problem.
- rexthecat
12 years 9 months ago #101899
by rexthecat
Replied by rexthecat on topic Brake warning light
Fair point, was a bit of a daft idea.
Cheers
Cheers
12 years 9 months ago #101965
by Rhinoman
Replied by Rhinoman on topic Brake warning light
The system is designed so that the light comes on when the brakes are worn down, for that reason you should only top up the fluid when the brakes are serviced.
Time to create page: 0.085 seconds
