Instrument Cluster lights
- The Dug
12 years 9 months ago #101651
by The Dug
Instrument Cluster lights was created by The Dug
Evening troops,
While driving home tonight I noticed that the centre of my instrument cluster was not lit???
right and left hand sides were normal but the centre section, from 70mph to 4000revs was dark.
Any ideas?
03 JLX by the way.
Any ideas?
03 JLX by the way.
12 years 9 months ago #101685
by kirkynut
Replied by kirkynut on topic Instrument Cluster lights
Blown bulb! You've a pain in the arse job of getting at it I'd imagine but I've not really looked into it.
Try switching the lights on and giving the dash above it a hard slap with the palm of a hand and see if magic makes it work again! I've had it on other cars before. Possibly just a bad connection, nonetheless a pain!
The following user(s) said Thank You: The Dug
- jonesyba420
12 years 9 months ago #101689
by jonesyba420
Replied by jonesyba420 on topic Instrument Cluster lights
my heater controls dont always light up, swift smack on the top of the dash turns em on
- markyp2000
12 years 9 months ago #101691
by markyp2000
Replied by markyp2000 on topic Instrument Cluster lights
Easy job remove 2 screws from around the speedo trim give it a good pull then remove speedo unit a few screws then find the bulb thats blown probs a 501bulb then test and refit easy only take about 15mins
- jonesyba420
12 years 9 months ago #101697
by jonesyba420
does that give you access to the back of the dials? is that where the annoying door beeper thingy is? (the beep beep when you leave the doors open with the keys in the ignition)
markyp2000 wrote: Easy job remove 2 screws from around the speedo trim give it a good pull then remove speedo unit a few screws then find the bulb thats blown probs a 501bulb then test and refit easy only take about 15mins
- jonesyba420
12 years 9 months ago #101707
by jonesyba420
just had a quick look at the instrument cluster, do you just unscrew the 2 screws that point upwards (in the reses where the dials are)? does this then release the whole black surround that goes round the dials and heater controls?
really want to stop the annoying beeping when you leave the keys in with the door open, have tried locating wires that other people have mentioned and they dont seem to apply to my J
i have read on here somewhere that the actuall "buzzer" is behind the dials.....................................is this correct?
Time to create page: 0.101 seconds
