25mm lift
  • 410shotgun
22 Jan 2014 09:06 #101549 by 410shotgun
25mm lift was created by 410shotgun
if I fit 25mm spring spacers to my rear springs on my jimny
do I need to change the rear shocks or will they be ok
or is there a long spring I can fit I only want it 1" or 25mm high
as it just looks a bit low at the rear
  • jonesyba420
22 Jan 2014 09:51 #101553 by jonesyba420
Replied by jonesyba420 on topic 25mm lift
what about shock extenders?
  • 410shotgun
22 Jan 2014 10:01 #101555 by 410shotgun
Replied by 410shotgun on topic 25mm lift
yes but do I need them
22 Jan 2014 11:10 #101559 by Busta
Replied by Busta on topic 25mm lift
Mine sits low at the rear, which I've put down to age. It may be that you just need to fit some new standard springs to restore it to how it should be. They will be cheap and won't require new shocks.
  • gipcyan bill
22 Jan 2014 12:14 #101564 by gipcyan bill
Replied by gipcyan bill on topic 25mm lift
Ive got 1 1/8" spring spacers on mine no problems after 3 year without doing anything to the dampers
  • 410shotgun
24 Jan 2014 08:53 #101806 by 410shotgun
I think I will put new springs on the rear and see
where is the best place to get them from
some on ebay for £17 each
