muddyzook rear disc fitting instructions
  • vitara_mad
18 Jan 2014 18:56 #101006 by vitara_mad
muddyzook rear disc fitting instructions was created by vitara_mad
has anyone got the fitting instructions for the muddyzook rear disc conversion plz
seems the instructions are no longer available on there website
  • markyp2000
18 Jan 2014 19:28 #101008 by markyp2000
Replied by markyp2000 on topic muddyzook rear disc fitting instructions
I fitted mine i a few hours what do you need to know
  • vitara_mad
18 Jan 2014 19:32 #101010 by vitara_mad
Replied by vitara_mad on topic muddyzook rear disc fitting instructions
markyp2000 wrote: I fitted mine i a few hours what do you need to know
how to connect handbrake cable
  • vitara_mad
18 Jan 2014 22:24 #101033 by vitara_mad
anybody ??????
  • markyp2000
18 Jan 2014 23:57 #101044 by markyp2000
You should have a metal sleve leave the spring on the cable and fit the sleave then put it through the hole on the caliper then hook the rectangle bit on the end of the cable then place on the caliper insert the pin then a split pin do all this after slacking the cable off at the hand brake hope this helps
  • vitara_mad
19 Jan 2014 01:23 #101049 by vitara_mad
I seem to remember reading something about needing part of the cable from the rover or am I wrong
Time to create page: 0.092 seconds
