Engine management light stays on
- TomDK
12 years 10 months ago #100691
by TomDK
Engine management light stays on was created by TomDK
A couple of weeks ago the light was on for a tiny moment, barely noticed it.
So today I was out for a short drive, the light stayed on with the engine running.
It's 2002 softtop, spanish model with G13BB engine.
What could cause this? The engine runs fine, nothing to notice, other than it's time for a timing belt change
Read something about a malfunctioning lambda sensor ??
12 years 10 months ago #100697
by kirkynut
Replied by kirkynut on topic Engine management light stays on
You need one of those obd1 readers in the Bigjimny shop or your just guessing, but having said that, if I were to guess I'd guess lambda sensor.
Try disconnecting the battery for a minute or so. That will put it out unless the problem persists at which point it will come straight back on or will do in a short while. You may be lucky and it may not come back on again.
- Reloaded
12 years 10 months ago #100702
by Reloaded
Replied by Reloaded on topic Engine management light stays on
On a 2002 you should be able to read the code with a cheap OBDII tool - I can on my 2001 Spanish soft top. I think that anything 51 plate on should be OBDII compliant.
- GuardianAngel
12 years 10 months ago #100704
by GuardianAngel
Replied by GuardianAngel on topic Engine management light stays on
Mine does exactly this some times.
It used to come on permanently as well sometimes, but has not done that since fitting a new CAT. It was knackered with loads of it broken up in the exhaust pipe!
But my engine runs really sweetly so I don't worry about it.
12 years 10 months ago #100707
by kirkynut
Trouble is passing any emissions tests as I think Tom is in Denmark. Not sure what hoops they make you jump through.
- TomDK
12 years 10 months ago - 12 years 10 months ago #100710
by TomDK
Replied by TomDK on topic Engine management light stays on
Probably similar tests to when you do the MOT.
They need to be inspected every 2 years. I had mine done about 1 year ago, so plenty of time to get i fixed, if it's only the lambda sensor.
But thanks for all you help. I'll probably visit the Suzuki dealer on my way home from work friday. They usually don't charge much, if anything, just to check the error code.
Last edit: 12 years 10 months ago by TomDK.
Time to create page: 0.087 seconds
