Can't slide temp slider?
- Sandspider
12 years 10 months ago #100048
by Sandspider
Can't slide temp slider? was created by Sandspider
Hi all
Bit of an odd one - the temperature control slider in my Jimny is stuck at the cold end. I can move it about a cm towards the hot end, then it stops, and feels like I'll bend or break something if I push any harder. Its not a good time of year to only have cold air!
Anyone had this problem, and how did you fix it? Do I need to take out the dashboard section? If so, how do I do that?
Many thanks.
Many thanks.
- markyp2000
12 years 10 months ago #100049
by markyp2000
Replied by markyp2000 on topic Can't slide temp slider?
Down by the clutch pedal there is a white pivot i think thats the hot cold flap see it the cable is attached
- Sandspider
12 years 10 months ago - 12 years 10 months ago #100051
by Sandspider
Replied by Sandspider on topic Can't slide temp slider?
Thanks. I'll check tomorrow in daylight.
But wouldn't the cable coming off mean that the slider would move easily, but the temp wouldn't change? Ie I wouldn't get a jammed slider?
Last edit: 12 years 10 months ago by Sandspider.
- idiotmobil
12 years 10 months ago #100053
by idiotmobil
Replied by idiotmobil on topic Can't slide temp slider?
I cant move mine I tried the white lever bit down by the pedal it moves but not to all the positions nearly all of them but not the one I want,(the screen) if you find out whats wrong let me know I havnt looked in to it to much just tried the levers each end seams to be broken in side some how
- Sandspider
12 years 10 months ago #100081
by Sandspider
Mine is the temp slider that's stuck, not the vent selector slider. Might be a similar problem though. I'll have a look tomorrow.
Anyone know how to get that part of the dash out? I had a look in the how tos, but that only covers a bit of dash removal on a facelifted Jimny, not my older model...
- Sandspider
12 years 10 months ago #100104
by Sandspider
Well, went out to investigate, and the lever moves as normal! Seems there was some white sticky stuff on the lever inside the dash, and the heat in the Jim in the sun today has melted it!
I've cleaned out the worst of it, and left it on hot.
I do wonder where the white stuff came from though... (No dodgy suggestions please!!)
Cheers for the help.
Time to create page: 0.092 seconds
