Ora behind bumper winch tray
  • ne-crock
08 Jan 2014 15:12 #99614 by ne-crock
Ora behind bumper winch tray was created by ne-crock
So set about fitting my winch tray today and it just doesn't fit?
Has anyone else has this problem, also checked out the fitting instructions linked on bits4vits and my mount doesn't look the same? It seems to have a cut out to fit around the end of the slam panel mine doesn't...
Also I've seemed to have miss placed The shim, is this just the same thickness as the plate because if so I'll make one up at work?
I don't think I'm being daft it just doesn't seem to fit?
Last resort I'll get the grinder out and make it fit
Cheers in advance
Mike
  • TomDK
08 Jan 2014 15:14 #99615 by TomDK
Replied by TomDK on topic Ora behind bumper winch tray
Why not give Rob @ ORA a call? Or email him? He's usually quick to answer.
  • markyp2000
08 Jan 2014 16:17 #99617 by markyp2000
Replied by markyp2000 on topic Ora behind bumper winch tray
Does it have air con cos im sure thay havnt made one for air con yet
  • Hastiekid
08 Jan 2014 16:36 - 08 Jan 2014 16:38 #99622 by Hastiekid
Replied by Hastiekid on topic Ora behind bumper winch tray
I have one fitted to the front of my truck Mike though I have no winch :blink: (My recovery points are mounted to it.)
Are you sure you have it set up right? Ignore all the Shims and bolt on plates at the start, lay the main structure on top of the rails. You should find it slots into place in the contours.
Ian
Last edit: 08 Jan 2014 16:38 by Hastiekid.
  • ne-crock
08 Jan 2014 17:38 #99641 by ne-crock
Replied by ne-crock on topic Ora behind bumper winch tray
TomDK wrote: Why not give Rob @ ORA a call? Or email him? He's usually quick to answer.
only just noticed this, proably give him a ring, i made a start adaprting my sub frames to fit my bucket seats, which came to a hault also i dont think i'm made for working on cars...
markyp2000 wrote: Does it have air con cos im sure thay havnt made one for air con yet
nope no air con, w reg soft top,
Hastiekid wrote: I have one fitted to the front of my truck Mike though I have no winch :blink: (My recovery points are mounted to it.)
Ian
unless my front rails are bent, it doesnt fit on shims or no shims
also how the ends of the rails have the mounts it seems to need a gap in the plate to allow it to slot in, but they foul, and also the gap down the side the plate seems slightly to thick,
i mean i'm not fab guy and not saying its rubbish, i'm just saying mine doesnt fit,
going to have another go tomorrow it might be a case the rails and bent, i'll get my grinder out and make it fit,
  • markyp2000
08 Jan 2014 19:22 #99659 by markyp2000
Can you put a pic up so we can see
Time to create page: 0.089 seconds
