Winch issues
- Jimbospanner
Topic Author
- Premium Member
- Thank you received: 9
05 Jan 2014 18:09 #99235
by Jimbospanner
Winch issues was created by Jimbospanner
Hi all,
Could anyone help me diagnose a faulty winch.
With power on and operating the controls in both the "in" or "out" positions, I can hear the relay operating but no power to the motor?
It's a superwinch bottom pull TS 9500. Not serviced in over a year and used quite a lot. (Winching my mates defender out)
Just after a starter for 10??
Thanks
Thanks
- TomDK
05 Jan 2014 18:11 #99236
by TomDK
Replied by TomDK on topic Winch issues
Have you checked all connections are 100% okay? No corrosion or any thing.
- Jimbospanner
Topic Author
- Premium Member
05 Jan 2014 18:16 #99240
by Jimbospanner
Replied by Jimbospanner on topic Winch issues
Not yet, I'll be attacking the issue next weekend! Trying to get some ideas together.
That will be the first inspection along with any fuses on the high amp side of the wiring.
Thanks tom.
Thanks tom.
- TomDK
05 Jan 2014 18:21 #99241
by TomDK
It can be as little as a loose nut or bolt on the solenoid or winch motor.
After I installed the second motor in my winch, there was no power to the motor. Turned out that I'd forgot to tighten the armature cable on the solenoid. It was only finger-tightened.
- Jimbospanner
Topic Author
- Premium Member
05 Jan 2014 18:31 #99243
by Jimbospanner
You are correct, must try the simple things first.
05 Jan 2014 21:25 #99279
by kirkynut
Replied by kirkynut on topic Winch issues
Once you've cleaned everything up and are sure all connections are good, take the motor out and see if the brushes have got stuck because of mud etc on them. If the brushes are stuck it'll work until they're worn so they no longer make contact and then it'll stop.
It could be one of many simple things though as has been said.
Time to create page: 0.170 seconds
