Brakes - knocking noise
  • 2013gary
05 Jan 2014 13:00 #99187 by 2013gary
Brakes - knocking noise was created by 2013gary
Hi,
I've just replaced my front calipers, discs and pads. After changing the brake fluid and bleeding the brakes I went out for a test drive. Now, whenever I brake there is a knocking noise. I checked both the calipers, carriers and discs to make sure there were no loose bolts and everything seems fine. There are no fluid leaks and the fluid level hasn't dropped. Any ideas?
05 Jan 2014 13:15 - 05 Jan 2014 13:22 #99188 by robs5230
Replied by robs5230 on topic Brakes - knocking noise
is this a constant knocking or a clunk as the pads engage with the disc ?
assuming the calipers are new ,is it possible there is an incompatibility between the discs and calipers ? thinner disc , bigger caliper ?
standard jimny - for now
Last edit: 05 Jan 2014 13:22 by robs5230.
  • 2013gary
05 Jan 2014 13:27 #99189 by 2013gary
Replied by 2013gary on topic Brakes - knocking noise
It's more or less constant knocking under braking. My initial thought was that either the caliper or the carrier wasn't secure but I checked and there is no movement or anything.
  • Wiltec17
05 Jan 2014 15:04 #99202 by Wiltec17
Replied by Wiltec17 on topic Brakes - knocking noise
Have you used cheap pads? I've seen brand new patent pads knock in the carriers simply due to them being such a poor fit.
  • markyp2000
05 Jan 2014 15:37 #99212 by markyp2000
Replied by markyp2000 on topic Brakes - knocking noise
Was there any spring shims on the carrier to stop the pads ratterling
  • 2013gary
05 Jan 2014 15:51 #99218 by 2013gary
Thanks for the responses. The calipers and discs are exactly the same as the originals I checked.
The pads and discs are Pagid which are quite cheap - maybe that's the problem.
As for the spring clips they are all present, although the anti squeal shims were quite a loose fit.
Time to create page: 0.270 seconds
