Running Hot
  • Olucas91
12 years 10 months ago #98660 by Olucas91
Running Hot was created by Olucas91
Notice the other day that my jimny was running warmer than it should. The temp gauge is about 3/4 up, level with the little black screw (01 model). Waited for it to cool down and checked the coolant, was brown in colour with what looked like a little oil think maybe the head has gone. Still runs fine and doesnt smell warm, only when been through puddles etc. Is it worth flushing the system and replacing coolant first to see what happens? If so what rad flush do you recommend and what colour coolant? Is red ok?
Thanks Ollie
12 years 10 months ago #98664 by facade
Replied by facade on topic Running Hot
If there is oil in the coolant, you are likely right about the head gasket having gone.
Best to get it changed, and the head skimmed flat.
I think just changing the coolant at this stage will be a waste of money.
Japanese vehicles tend to use a green antifreeze, but the colour doesn't mean much.
The red OAT longlife stuff is not recommended for engines containing copper or brass- I don't know what the heater is made out of.
I'd put the quality blue antifreeze in it to be safe.
12 years 10 months ago #98665 by kirkynut
Replied by kirkynut on topic Running Hot
I think rather than waste coolant if the head gasket has gone you should get a good trustworthy local garage to do some tests, or do them yourself. Such as the sniffer test, compression tests etc.
Is there an issue that's caused it to overheat and thus the headgasket to fail if it has? Blocked rad, stuck shut thermostat, viscous unit on the fan not working?
If there is a problem, you need to solve that as a cause also.
Then get some coolant from a motor factor and they will guide you on what to use as different manufacturers use different colour dye.
Hope this helps.
Time to create page: 0.066 seconds
