servo issue I think
  • jimny-bob
01 Jan 2014 15:29 #98564 by jimny-bob
servo issue I think was created by jimny-bob
Hi all
my brake pedal is normal when I first start the car but it goes soft. Sometimes it comes back hard, I think its the pipe between the inlet manifold and the servo could be spit but I cant see any splits.
The pipe has a hard bit in it! Does anyone know if its a non return valve?
  • markyp2000
01 Jan 2014 16:46 #98574 by markyp2000
Replied by markyp2000 on topic servo issue I think
If you lose servo assistance you pedal would be hard all the time and if you had a split you would here a hissing sound as air is being drawn in and the engine would run lumpy
02 Jan 2014 12:13 - 02 Jan 2014 13:17 #98669 by kirkynut
Replied by kirkynut on topic servo issue I think
I think the way to check a servo (trained mechanics correct me if I'm wrong) is to pump the pedal with the engine off and leave your foot pressing on it, then start the engine.
If the servo has a leak or fault the pedal will stay hard in the same place, if not it shall go down a little then stay hardish.
There is a non return valve but it's usually where the vacuum pipe goes into the servo. Not looked on my Jimjam.
Last edit: 02 Jan 2014 13:17 by kirkynut.
  • Dave cc
02 Jan 2014 12:57 #98687 by Dave cc
Replied by Dave cc on topic servo issue I think
Sounds a bit like the old Guardian Angel scenario wasn't his a failed wheel bearing or something like that :unsure:
  • markyp2000
02 Jan 2014 13:17 #98691 by markyp2000
kirkynut wrote: I think the way to check a servo (trained mechanics correct me if I'm wrong) is to pump the pedal with the engine off and leave your foot pressing on it, then start the engine.
this is correct
02 Jan 2014 13:25 #98693 by kirkynut
Dave cc wrote: Sounds a bit like the old Guardian Angel scenario wasn't his a failed wheel bearing or something like that :unsure:
Makes sense as when the hub wobbles the disc mounted on it wobbles & pushes the caliper back in so it needs pushing that much back out and needs the pedal travel to do so.
