Electrical Gremlin / Bodge - Speedo?
  • Jimny-Dave
12 years 10 months ago #97795 by Jimny-Dave
Electrical Gremlin / Bodge - Speedo? was created by Jimny-Dave
Hoping someone can help me out...
I don't use my Jimny that much as I live next to where I work... so sometimes when I get in it the battery is flat, quite annoying! So i've had a new battery, but no difference, still flat if I don't use the trucklet for a few days...
Dead again this morning after not moving for a few days over Christmas, so I jumped it off the Vitara and took it for a spin to charge the battery up, and then started looking at the electrics, figuring it must be something drawing a current to flatten the battery after a few days standing.
To cut a long story short, I found a 15amp fuse in a holder next to the battery, wired into a ring connector which is clamped on with the battery cable - so it's a permanent live - and it heads off through the bulkhead and into the dashboard. So, I figured I'd pull it out and see what then didn't work, nothing it seemed, everything worked as normal, it started and ran fine, so I took it for another spin... and then noticed the Speedo was no longer working?! :unsure:
So I headed home again and popped the fuse back into the holder, but now the Speedo still doesn't work...
So, a couple of questions...
1) Does the Jimny have an electrical speedo then? rather than a manual cable operated one I'm used to with Vitaras? I guess it does as I've seen / heard of speedo pickups for crawler boxes to power the speedo...
2) So, based on that, and my Speedo no longer working... can anyone draw on experience / knowledge to suggest what this possible bodge is for? Or is it just a coincidence? i think not somehow though?
I figure the fact that this is a permanent live, it must be some kind of bodge by a previous owner, and that the fact that it's permanent live is drawing current and flattening by battery over times of non-use.
Hopefully someone can point to why it's been done, and I can get my auto-electrician mate to have a look at it, and either sort it, or move this mystery fuse / wire to a switched live?
If it helps, the Jimny has an aftermarket alarm / central locking fitted, just in case that gives any pointers...?
Cheers in advance, Dave
12 years 10 months ago #97796 by mlines
Can't answer the electrical questions,but the speedo is electric.
Common issue is that it stops working, common fix is to disconnect the battery for a few minutes.
Sent from my HP Slate 7 using Tapatalk 4
  • RichiesJimny
12 years 10 months ago #97797 by RichiesJimny
Replied by RichiesJimny on topic Electrical Gremlin / Bodge - Speedo?
Try disconnecting the battery that seems to have sorted a few people's speedos out
  • Jimny-Dave
12 years 10 months ago #97800 by Jimny-Dave
Replied by Jimny-Dave on topic Electrical Gremlin / Bodge - Speedo?
Thanks guys, about to nip out and disconnect the battery then, whilst I go and fuel up the Vitara for another days greenlaning tomorrow :D
12 years 10 months ago #97802 by funkyjimny
Roll on tomorrow !
Bin the extra alarm Dave!
Just bleeding my rear brakes after fitting the locker
See you in the morning
Gary
  • Jimny-Dave
12 years 10 months ago #97808 by Jimny-Dave
Hmmm, left the battery disconnected whilst I went to fuel-up the Vit and check the air pressures - Henryd tomorrow again! Blog coming! (Yes, see you in the morning Gary! :woohoo: )
Got back, disconnected the rogue permanent-live fuse (presumably the after-market alarm) and then reconencted the battery...
Speedo now works?!
Weird, must have been an odd coincidence?...
So left alarm disconnected, have switched light off so it doesn't stay on if a door is left ajar, and have disconnected rear hardtop window demister (as that's the only electrical thing I can think I've ever changed since having the Jimny), and will now see how it get on... if I get in it in a few days and it doesn't ^$%^$%^$ start, it's going on eBay! LOL ;)
Thanks for your help getting the speedo working Martin & Richie, much appreciated...
Cheers All!
Dave
