Modifying front brakes
- gus2000
27 Dec 2013 11:25 #97660
by gus2000
Modifying front brakes was created by gus2000
Hello everyone. I need repair Jimny front brakes. Talking with my friend, Diego came a few ideas:
By increasing the diameter of the original tires, increase the braking torque requirements. this led us to evaluate the alternative of placing brakes suitable for higher loads.
Searching the bigjimny, I find ticonauta good idea
www.bigjimny.com/index.php/forum/8-my-ji...imitstart=0&start=12
Install (without modification) discs and calipers of the Sidekick (or GV 3p), that are ventilated and calipers pistons are 12% larger (the Jimny have pistons diameter of 51mm, while the 54mm diameter vitara are. that's 1.12 times more force for the same pressure on the brake pedal)
Assemble to evaluate a used disc
As they all went perfect, came new items
Discs, pads and calipers repair kit
The pistons used are immaculate was not necessary to replace
The calipers are the Sidekick brand Tokico (the Jimny factory are Aisin)
Repaired with the kit.
Making assembly
Views of Mount
The calipers are larger but pass right by the rim
And by the kingpin
Care: in the Jimny the calipers are located horizontal, and in the sidekick inclined. so that the bleed hole to accomplish its mission properly, we must purge with the caliper tilt.
The first test results are excellent, the brake pedal down a little more because the pistons in the calipers are larger and need larger amount of fluid. Less force is required on the pedal and the braking is smooth and progressive.
Thanks Diego.
Gustavo
Making assembly
Views of Mount
And by the kingpin
Thanks Diego.
Gustavo
- gus2000
27 Dec 2013 12:30 #97663
by gus2000
Replied by gus2000 on topic Modifying front brakes
Hello MysticRich
I adquire sidekick brake calipers used, and repair these.
The original jimny brake lines are not modified (only requires 4 new copper washers 10 x 15 x 1.5 mm)
both brake discs have the same dimensions (sidekick and jimny)
Cheers
Gustavo
Cheers
Gustavo
Time to create page: 0.134 seconds
