Transfer box banging/thumping ?
- jonesyba420
27 Dec 2013 10:06 #97652
by jonesyba420
Replied by jonesyba420 on topic Transfer box banging/thumping ?
Also check the prop shafts for movement/play at the UJ's and while under there check the vac hoses are still attached at the hubs then follow their route and look for obvious breakages.
Does it drive fine in RWD with no random noises?
- piprice
27 Dec 2013 10:13 #97653
by piprice
Replied by piprice on topic Transfer box banging/thumping ?
Only concern is the rumbling when say in 3rd under 2k rpm which is deffo not from engine but a prop?
Also crunching 1st / reverse going down hill but fine on flat
- jonesyba420
27 Dec 2013 10:22 #97654
by jonesyba420
Could be a uj causing the rumbling, never heard much said about them on here tho tbh. Quite a common problem on lifted LR's, changed one on my dads not so long ago was loads of play in it!! Grab the prop,there should be no sideways movement.
Might not be the problem im no expert, but you can check the things you can see yourself before paying a garage to investigate.
As for gear crunching downhill I have no idea.
- piprice
27 Dec 2013 10:28 #97656
by piprice
I think crunching could be low oil maybe in either diff or gearbox maybe or even because clutch is coming to the end of its life or even cable stretched.... Pass
- jonesyba420
27 Dec 2013 10:35 #97658
by jonesyba420
Id think low gearbox oil would mean crunching in all gears.
- piprice
27 Dec 2013 19:45 #97696
by piprice
Right today I got a solid green light in 4 high unsure if it engaged though as I appeared to do a full donut lol
Could not get any light then not even flashing and again when 4l is selected you
Drive back a few yards and it bangs
When I move the selector it thumps, so could this be the mount?
With the weather I've not been under it to look but can only describe what I've done in the cabin!
Time to create page: 0.098 seconds
