bump stops
  • mudman
19 Dec 2013 23:35 #96883 by mudman
bump stops was created by mudman
Just a quickie just wondering how people have extended there bump stops really need to do mine
  • TomDK
20 Dec 2013 00:11 #96885 by TomDK
Replied by TomDK on topic bump stops
Just got these.
Will be installed on the chassis right next to the springs. Only doing the front.
  • Reloaded
20 Dec 2013 08:01 #96899 by Reloaded
Replied by Reloaded on topic bump stops
Mine has steel extensions bolted to the axle.
  • TomDK
20 Dec 2013 18:57 - 20 Dec 2013 18:58 #96961 by TomDK
Not a lot af shocks comes with internal bump stops. And if they do, they're not that good.
Last edit: 20 Dec 2013 18:58 by TomDK.
  • TomDK
20 Dec 2013 20:17 - 20 Dec 2013 20:23 #96980 by TomDK
Internal bump stops are better than nothing. But still a bad excuse for real bump stops.
I know the ones I've just gotten are perhaps a bit overkill. I really wanted Fox hydraulic bump stops. But can't really find place to fit them anywhere. So I got these instead, which allow for a bit more travel, before bumpstopping. The internal ones are only a few mm's of rubber to prevent metal from hitting metal.
As you can see in the video, this works much better. But to fit something like this to the Jimny the entire front chassis suspension mounts have to be altered.
Last edit: 20 Dec 2013 20:23 by TomDK.
  • TomDK
20 Dec 2013 20:55 #96987 by TomDK
Bling?
No bling, just how it should be on a Jimny :)
Time to create page: 0.173 seconds
