paranoia. possibly.
18 Dec 2013 12:17 #96651 by Lambert
paranoia. possibly. was created by Lambert
Since I did the last service last week I don't think it is as smooth running as it was. It is only very marginal and only around 1900 to 2400rpm and then only under load. It had new oil and filter and an air filter and a new set of iridium ngk plugs gapped to 1.1mm. All I can think of is tightening the plug gaps to 1.05mm?
What else can it be? ? just after the issue of binding pads for the mot and the death wobble that caused I'm a bit twitchy with it. It still goes well and if I accelerate through I don't notice it.
Cheers.
  • Yellostreak
18 Dec 2013 13:36 #96660 by Yellostreak
Replied by Yellostreak on topic paranoia. possibly.
it is possible to buy dodgy plugs... if it was running fine pre service then put the old ones back in and also check the plugs leads are fine..
19 Dec 2013 15:29 #96803 by Lambert
Replied by Lambert on topic paranoia. possibly.
Ok so I have put the old ones back in and all is well. I also looked at the book again and I have miss read the interval the plugs are not due till next year or 36k. Will go get my money back on the other ones I bought. All is well. Cheers.
19 Dec 2013 17:20 #96813 by facade
Replied by facade on topic paranoia. possibly.
I put NGK irridium plugs in my 'bike a while ago, purchased online (not ebay, someone who you would expect sells genuine plugs) having read all this blurb about better spark allowing smoother running and a leaner mixture etc.
It seemed to run rough as you say, so I put the originals back in and all was well. Still have the irridiums on the shelf in the shed.....
  • idiotmobil
19 Dec 2013 18:11 #96822 by idiotmobil
Replied by idiotmobil on topic paranoia. possibly.
ive tried iridium plugs before in my motocross bikes and they run rough and pop plugs all the time tried them in a few other thing and wont use them anymore, I find them to unreliable over standered plugs
  • Wiltec17
19 Dec 2013 19:24 #96847 by Wiltec17
Replied by Wiltec17 on topic paranoia. possibly.
I must admit I had a iridium NGK go down on my bike, ran on three cylinders below 3k when hot. I think any gains would be minimal anyway, probably not noticeable on standard car
Time to create page: 0.195 seconds
