goodwinch 9.5i vs 9.5c?
  • ne-crock
16 Dec 2013 19:49 #96450 by ne-crock
goodwinch 9.5i vs 9.5c? was created by ne-crock
so which is better? it will be hidden behind standard bumper? will it fit?
differences one bridges across the winch the other is in a box in the end?
any pro's/cons?
cheers
crock
  • TomDK
16 Dec 2013 20:32 #96457 by TomDK
Replied by TomDK on topic goodwinch 9.5i vs 9.5c?
Personally I don't like the bridge model. You're restricted from fitting the solenoid other places. But other than that, they're the same. But I'd get the 9.5c as it's a smaller fit.
  • ne-crock
16 Dec 2013 20:40 #96458 by ne-crock
Replied by ne-crock on topic goodwinch 9.5i vs 9.5c?
i got impatient and ordered the c so its all good, now to buy some wire, anything else needed should i put a large inline fuse in?
  • TomDK
16 Dec 2013 20:50 - 16 Dec 2013 20:52 #96459 by TomDK
Why would you buy wire?
The winch comes with everything needed.
No reason for a fuse. But a battery cut of switch of some sort is not a bad thing.
Last edit: 16 Dec 2013 20:52 by TomDK.
  • ne-crock
16 Dec 2013 21:02 #96461 by ne-crock
oh does it? i never knew that, well that saves me a purchase,
i'll have a look into the switches,
i know theres been lots of question on batterys but is there any limitations to what batteries you can use? apart from physical size?
was very impressed one day with a vatra 300tdi disco battery they have like 850cca and mamaged to winch smoggys truck about 1-2 miles with no engine to charge it, and still started the disco after
  • TomDK
16 Dec 2013 21:17 - 16 Dec 2013 21:18 #96463 by TomDK
Goodwinch sells cut off switches. Give them a call tomorrow, perhaps they'll give you a good deal on one along with the winch :)
What battery have you now? The standard battery is not suitable for winching, but can be okay to get you started.
It really is down to how much money you want to spend on a battery. An odyssey pc1200 fits the Jimny and is great for winching, but costs around £180. Otherwise Numax are great on a budget, but won't fit the standard battery tray. Use the search function as there been some writing about bigger batteries and where to place them.
Also take a look at the tray from jimnybits.
Last edit: 16 Dec 2013 21:18 by TomDK.
Time to create page: 0.089 seconds
