Banging from OSF hub
- danstangoe
12 years 11 months ago #95968
by danstangoe
Banging from OSF hub was created by danstangoe
A banging noise has started on my OSF when in 4x4. When RWD is selected there is no noise, even when the manual locking hubs are locked there is no noise. Only when 4x4 is selected is starts, its a loud bang that happens constantly as soon as the wheel is turned slightly. Its to dark to have a look now, just wondered if anyone had any ideas.
Sent from my GT-I9505 using Tapatalk
12 years 11 months ago #95980
by facade
Replied by facade on topic Banging from OSF hub
Most likely the CV joint, the hub has to come apart to pull the halfshaft complete with CV.
- danstangoe
12 years 11 months ago #95981
by danstangoe
Replied by danstangoe on topic Banging from OSF hub
Would it not knock all the time if it was the cv joint?
12 years 11 months ago #95988
by kirkynut
Replied by kirkynut on topic Banging from OSF hub
CVs make a loud clicking more than banging noise but it's the likely suspect. They are only going to turn when in 4wd on vacuum hubs and only when under drive on locked manual hubs will they click.
They may just be dry of grease rather than need replacing.
- danstangoe
12 years 11 months ago #95992
by danstangoe
its really bad mate, Just started after going off-road this afternoon. On tarmac you can literally feel it through the car.
12 years 11 months ago - 12 years 11 months ago #96002
by kirkynut
There lies your problem if you are in 4wd on tarmac! You must not be in 4wd on tarmac! You have no centre diff and are winding up tension in your transmission! It has to get released somehow and does so by breaking something!
Find some wet grass to test it in 4wd again & with fingers crossed it may be ok.
Last edit: 12 years 11 months ago by kirkynut.
Time to create page: 0.095 seconds
