Earthing fault?
- professor
12 years 11 months ago #95638
by professor
Earthing fault? was created by professor
I was driving and the battey light was randomly flickering and everything was ok untill I drove over a small grass verge about a foot high
there was bang from underneath and the headlights dimmed and the battery light came on permantly
I checked the voltage at the battery and the altenator did not appear to be charging,so i'v changed the altenator and still no joy
any ideas?
any ideas?
- Wiltec17
12 years 11 months ago #95661
by Wiltec17
Replied by Wiltec17 on topic Earthing fault?
Have you checked your belts are still intact.? Also check the pulleys are all turning, I've seen belts spin on a seized altenator pulley.
- professor
12 years 11 months ago #95663
by professor
Replied by professor on topic Earthing fault?
checked all the pulleys when I fitted altenator.also fitted new belts
- greenjimny
12 years 11 months ago #95671
by greenjimny
Replied by greenjimny on topic Earthing fault?
the main alt wire runs into the fuse box on the inner wing to an 80 amp square black fuse with two retaining bolts . check this its possibly burst with a surge as you alt died
hope this helps
hope this helps
- professor
12 years 11 months ago #95680
by professor
thanks I'll check it now
- professor
12 years 11 months ago #95685
by professor
check it and it's ok
Time to create page: 0.119 seconds
