remove shock extension will stiff suspension?
- topjimny
12 years 11 months ago - 12 years 11 months ago #95218
by topjimny
remove shock extension will stiff suspension? was created by topjimny
Hi guys,
I have recently removed my sway bar and the front end is a bit jelly. It's confortable and good off road. The car fell much less rigid on bump stops too. But there is a test I always do by braking hard when changing lanes fast and my front tires now squeals and tend to slip.
I have a 3.5" coil lift and front shocks that are 17.7" extended and circa 11" closed. Bought them for a 2' lift, but i use shock extensions (+38 mm) to cope wih the coils. The shocks are soft by nature (OME), but don't bottom in or out even in the hardest bumps.
Question is if by removing front shock extensions will it be firmier due to pre-tensioned state or i'm mad and just need new shocks or sway bar back in? I'm trying to understand the behaviour of a shock before doing some work down there. Dunno if it's a basic question.
thx a lot...
thx a lot...
Last edit: 12 years 11 months ago by topjimny. Reason: typo
- Jimny_Aus
12 years 11 months ago #95243
by Jimny_Aus
Replied by Jimny_Aus on topic remove shock extension will stiff suspension?
no i'm doubting it will be firmer...... by removing the extensions, the shock will still perform with the same dampening extended or not....with out the roll bar it will feel alot 'looser' but ive had mine removed for a year now, done heaps of highway k's and its something youll get used to.
hope this helps...
hope this helps...
- topjimny
12 years 11 months ago - 12 years 11 months ago #95263
by topjimny
Replied by topjimny on topic remove shock extension will stiff suspension?
Thanks for the reply. Problably will need to get used to. I like the feeling with no sway bar. It's just on an extreme situtation that i'm worried. But car now feels like a Defender. More pleasant to drive around.
- jonesyba420
12 years 11 months ago #95264
by jonesyba420
Replied by jonesyba420 on topic remove shock extension will stiff suspension?
its best to try avoid the extreme situations like hard breaking whilst turning, no ARB is much better offroad
- darthloachie
12 years 11 months ago #95270
by darthloachie
Replied by darthloachie on topic remove shock extension will stiff suspension?
- jonesyba420
12 years 11 months ago #95271
by jonesyba420
quality picture, abit worrying :ohmy: only to people with no nuts tho :laugh: :laugh:
Time to create page: 0.108 seconds
