clutch question
  • Mick C
09 Dec 2013 18:47 #95175 by Mick C
clutch question was created by Mick C
Anyone had a new clutch installed and found that the cable adjuster is immediatley on the limit, ie wound right in leaving no scope for future adjustment?
09 Dec 2013 19:06 #95182 by facade
Replied by facade on topic clutch question
You mean the nut is wound right up the cable so it is out of thread?
As the clutch wears the arm has to move outwards (as the plate is thinner), so the cable is too tight, and you need to wind the nut along the cable (towards the pedal) to shorten the outer.
If it is already at max shortness, something is wrong and not hooked together right, you may find the cable outer is not fully in the socket at the pedal end.
  • Mick C
09 Dec 2013 19:58 #95190 by Mick C
Replied by Mick C on topic clutch question
facade wrote: You mean the nut is wound right up the cable so it is out of thread?
Ok thanks mate - yes it's at max shortness - right up t'buffers lol - by in the socket do you mean on the engine side of the bulkhead?
  • winter
09 Dec 2013 20:51 #95201 by winter
Replied by winter on topic clutch question
what typr of cluch have you put in it?????????????????
  • Mick C
09 Dec 2013 21:13 #95206 by Mick C
I didn't fit it, but it was an off the shelf kit, CK9742
10 Dec 2013 06:05 #95256 by facade
Yes, I've never had occasion to mess with the pedal end, but there must be something that the cable outer fits into, and a hook at the pedal arm.
Can't think of what else it could be, unless something is wrong at the arm inside the bellhousing
Time to create page: 0.091 seconds
