clutch question
- Mick C
As the clutch wears the arm has to move outwards (as the plate is thinner), so the cable is too tight, and you need to wind the nut along the cable (towards the pedal) to shorten the outer.
If it is already at max shortness, something is wrong and not hooked together right, you may find the cable outer is not fully in the socket at the pedal end.
- Mick C
facade wrote: You mean the nut is wound right up the cable so it is out of thread?
Ok thanks mate - yes it's at max shortness - right up t'buffers lol - by in the socket do you mean on the engine side of the bulkhead?
- winter
- Mick C
Yes, I've never had occasion to mess with the pedal end, but there must be something that the cable outer fits into, and a hook at the pedal arm.
Can't think of what else it could be, unless something is wrong at the arm inside the bellhousing
