Lockright in front diff?
  • darthloachie
12 years 11 months ago #95154 by darthloachie
Replied by darthloachie on topic Re:Lockright in front diff?
we've got a front ARb and you definately don't want to have it locked and then steer
you will get a clunk and then a new halfshaft is required :unsure:
the jimny is pretty capable without a front locker - we rarely use it - usually only if we want to do this:
12 years 11 months ago #95241 by Busta
Replied by Busta on topic Lockright in front diff?
I bought this subject up a few months ago and the gist of the conversation was that nobody had tried it but most thought it was a bad idea. However an internet search revealed that the fitting of lockright style diffs to the front-only is fairly common in some other 4x4s as a budget way to increase traction without upsetting on-road (2wd) driving characteristics.
Powertrax have this to say about the subject:
"The Powertrax Lock-Right Locker works well on the front axle of 4-wheel drive vehicles provided a couple of important guidelines are followed. The Lock-Right Locker should be used only on vehicles equipped with locking hubs on the front axle or with front axle disconnect. In addition, the vehicle must not be equipped with full time 4-wheel drive. Vehicles equipped with a Lock-Right Locker on the front axle should not be operated on the highway with the front hubs locked and 4-wheel drive engaged. Following these guidelines will ensure very on-road driveability while still providing maximum off-road traction."
Personally I'm still holding out to hear from someone who has real experience of doing it, or to try it myself. But from what I gather it will work fine.
  • Barrygsi
12 years 11 months ago #95317 by Barrygsi
Replied by Barrygsi on topic Re:Lockright in front diff?
@Busta- my thaughts exactly! But like you say the only way to find out is to actually try it. Maybe the next time ive got a spare £250 i will ;-)
Sent from my GT-I9100P using Tapatalk
  • Mister Stu
12 years 11 months ago - 12 years 11 months ago #95322 by Mister Stu
Replied by Mister Stu on topic Lockright in front diff?
Can see it being a problem on the road with the hubs unlocked but it'll put alot of extra strain on the front CV's when on 3 wheels or really rough ground or tight monuvers
Last edit: 12 years 11 months ago by Mister Stu.
12 years 11 months ago - 12 years 11 months ago #95338 by Busta
Here's a link to the previous thread, in which a lot of the points raised here were covered. www.bigjimny.com/index.php/forum/7-jimny...te-in-the-front-only
Last edit: 12 years 11 months ago by Busta.
  • ingolfurkolb
12 years 9 months ago #103728 by ingolfurkolb
Replied by ingolfurkolb on topic Lockright in front diff?
Hello guys,
Putting Lockright in front I say yes, no problem. My father has had this in his Samurai at the front for 3 years and I have to say it has worked out really well. When driving the car in 4x4 you dont notice the diff locking at all when turning. And always rotates both wheels when needed.
Car is fitted with lock hubs that are most often disengaged, but when we go out of town off-roading, to glaciers or to the highland they work well. Samurai is fitted with 1600cc vitara engine and 35" tires.
Im now ordering a lockright for my Jimny. Not sure if I will fit at the rear or front.
In my mind the front is safer option as it will not wear out as fast. I have heard they can get a bit noisy when started to wear.
To fit the 1510 lockright in the front you need a four pin carrier. They can be bought here, www.rocky-road.com/samurai-4-pin-carrier.html
Hope this helps,
Ingó
Time to create page: 0.099 seconds
