gearbox mount movement,
  • ne-crock
12 years 11 months ago #94911 by ne-crock
gearbox mount movement, was created by ne-crock
so the jimnys stugaling to select gears, to the point its dificult to drive
trying to find the cause of the problem, the mounts seem okay, i'm just curious to know how much play there should be if i lift the gearbox by hand underneath?
  • RichiesJimny
12 years 11 months ago #94913 by RichiesJimny
Replied by RichiesJimny on topic gearbox mount movement,
You shouldn't be able to lift the back end of the gearbox at all it sounds like the rear mount has come apart Mike.
  • ne-crock
12 years 11 months ago #94917 by ne-crock
Replied by ne-crock on topic gearbox mount movement,
Ah should the bush be solid all the way through not 2 split studs in the bush like original box mounts?
I think I've found my problem as it lifts about an inch I'll try get this sorted by the 21st
  • RichiesJimny
12 years 11 months ago - 12 years 11 months ago #94919 by RichiesJimny
The mount should be in one piece but it tends to split, I think they're around £35 plus vat from the stealers.
Last edit: 12 years 11 months ago by RichiesJimny.
  • ne-crock
12 years 11 months ago #94921 by ne-crock
is there no hd upgrade for them?
i'll have a look into it and find out
cheers richie
Time to create page: 0.147 seconds
