Lift Kit Question
- methylether
12 years 11 months ago #94711
by methylether
Lift Kit Question was created by methylether
Hi, I bought a Jimny recently to replace my Vitara and it already has a lift kit on, and its quite a tall one. I have banana front springs and the self centering is non existent. I know that by fitting the longer springs, the axle has rotated and now I have the wrong caster angle, and different radius arms will fix this. The question that I have is that I'm not sure how tall the lift kit is, so I don't know which radius arms to get, I.e 2.5 correction, 3" correction 4" etc. I was wondering if someone could measure from the wheelarch to the centre of the hub and tell me the measurement, including any lift they have, so I can work out how much lift I have.
Also, the panhards sit at quite an angle at ride height, should I get the relocation kit so they are level? Would that improve thins as well?
Thanks!
James
Sent from my GT-I9300 using Tapatalk
Thanks!
James
12 years 11 months ago #94718
by kirkynut
Replied by kirkynut on topic Lift Kit Question
If you look in Jimny Chat there's a sticky at the top called How Tall's Your Jimny. That should help you as it has all sorts of combinations for you to see.
- methylether
12 years 11 months ago #94719
by methylether
Replied by methylether on topic Re:Lift Kit Question
Brilliant! I didn't think to look in there! Thanks a lot!!
- macguyverjimny
12 years 11 months ago - 12 years 11 months ago #94721
by macguyverjimny
Replied by macguyverjimny on topic Lift Kit Question
I would say get under the car and determne if you have CC bushes on or not,
Then i would suggest you go to a wheel tracking/wheel allignment workshop to measure your caster,
If its around 3 degrees-4 degrees negative then its about a 3" lift,
Compression of the springs will also depend it you have a front bar, a winch a rolcage, and then also diesel vs petrol. Meaning the springs can be compressed to handle some sort of extra load...or not depends on you rig,
Do you still have stock panhards on there? Do your axles appear offcentre in terms of the allignment to the body?
Look at the thead :How tall is your jimny: that would give you some measurements
If i were you i would get 4" corrected arms
Goodluck
Goodluck
Last edit: 12 years 11 months ago by macguyverjimny.
