Odd noise coming from drivetrain i think
- neo
04 Dec 2013 22:23 #94616
by neo
Odd noise coming from drivetrain i think was created by neo
Hi guys just like to say hi and im new here my names Rob and live in Durham ive just purchased a Jimny for the Wife as she has always wanted one and what I thought was a good little motor might not be after all :S
Hopefully it might be an easy fix but wont hold my breath ive no luck with cars ..
Ok, see if you guys can point me in the right direction maybe fingers crossed...
2002 Jimny Manual gearbox 80,000 miles very clean tidy car but its got an odd noise, we collected it 3 days ago and been in 2wd since done about 90 miles and all seems fine, but today I tried the 4x4 side of things out on some some mud/brass engaged great worked great and was great drove 500yrds off mud on tarmac at about 20/30 mph and stopped shifted to 2wd and carrryied on again no issues for about 800/900 yeards then at about 30mph what can I only describe as a screeching sort of noise from what appears to underneath it was loud I nearly cacked myself so slowed to a stop and at about 5mp it stopped so I carried on again it did it again different speed same noise so I stopped again farted around with 4wd stick a bit and reversed 50ft then carried on again then all seemed well, so I tried it again back in 4x4 and then out again then it seemed fine again also..
So I don't know if it will do it again or not but its very loud and a bit of a concern, its not a fan belt noise or nothing like that its as though its a collapsed clutch plate or gearbox bearing noise or something like that but people walking by could hear it and it just came on and went off again when I almost stopped weird...
I did slightly notice that whist driving in 4x4 mode the jimny pulled to the right a bit but not in 2wd at about 30mph or there abouts not sure if its related but worth mentioning
Any ideas guys have I bought a pup ???
cheers Rob in advance
- rut
04 Dec 2013 23:01 #94625
by rut
Replied by rut on topic Odd noise coming from drivetrain i think
hi rob
welcome, i'm from durham as well iv a 2000 jimny, was the noise an engine/gearbox noise or wheel drive shaft noise, was it wet were you were driving
- neo
04 Dec 2013 23:44 #94628
by neo
Replied by neo on topic Odd noise coming from drivetrain i think
Hi Durham too eh cool
It was more like gearbox noise to me or clutch noise ( you know the noise a starter motor makes after its started as the the starter stops that long groaning whine screaming type noise like that but louder)
It was bone dry mate...
wasn't brake related at all..
wasn't drive shaft noise as it went off soon as I stopped and pulled away again
it was like a dry bearing type noise or collapsed bearing type noise but has been fine since I stopped and restarted it seems to do it 2/3 times after ive been in 4x4 and then seems ok I think not drove it that much frightened case I bust it big time sort of thing....
05 Dec 2013 00:01 #94631
by Busta
Replied by Busta on topic Odd noise coming from drivetrain i think
Sounds like a small stone stuck between the brake disc and shield to me. Quite common on lots of cars, and sounds pretty horrendous and reversing normally cures it.
- neo
05 Dec 2013 20:43 #94698
by neo
Hi busta cheers for the idea mate but its deffo more mechanical than that mate, its only doing it after ive been in 4x4 and then came out again whilst in 2wd after and its random when it comes on its a proper screaming type noise but with a dry sound too it etc >>>
Rob
Rob
- Yellostreak
05 Dec 2013 23:34 #94743
by Yellostreak
Replied by Yellostreak on topic Odd noise coming from drivetrain i think
transfer box? lack of oil or knackered bearings or something.. might explain why its only in 4wd..
Time to create page: 0.099 seconds
