2" lift advice
  • Eders
04 Dec 2013 06:29 #94492 by Eders
2" lift advice was created by Eders
Hi all, can I just say that this forum looks awesome given the amount of advice available.
I am about to put a 2" lift on my jimny, it will be used to get me to and from work (about 10m per day) and then for casual weekend off-road use. I am going to get a 2nd set of wheels (standard for on road) and was look at the 15x7s on jimnybits as a set of off road wheels. I do not really want to star cutting the car up or at least keep it minimal and out of sight, any advice on the best tyre size??
Would also be grateful for any must have beginner advice such as guards and stuff as I need to ensure that the car will get me to work on a Monday!!
  • jonesyba420
04 Dec 2013 08:00 #94493 by jonesyba420
Replied by jonesyba420 on topic 2" lift advice
First off hello and welcome aboard :cheer: where are you from?
you will find everything you will ever need to know about your jimny on here.
secondly, regarding your questions we as a collective need some more info, what year is your jimny? We need to know this as it affects what tyres you can run without any arch trimming.
under body protection is a must if its your daily driver unless you fit huge lifts, wheels, tyres to increase ground clearance.
ORA or jimnybits do the guards although they dont both do all the guards. Most recomended are transfer box and radius arm mount guards (where they join the chassis) and rear lower shock mount guards. Yoy can get front lower shock mount guards but not many people seem to fit these.Protecting the diffs is abit more tricky, ORA do a weld on option but peoples opinions vary when it comes to welding on the axle can cause damage, KAP do a bolt on skid plate option but it costs ALOT, there are a few import options but again these tend to be expensive. Most people seem to make their own or get them fabricated which is what I did, cost me £25 for the front.
the jimny is very capable with a decent set of tyres and under armour to put your mind at ease ;)
  • Barrygsi
04 Dec 2013 11:58 #94513 by Barrygsi
Replied by Barrygsi on topic 2" lift advice
Sent from my GT-I9100P using Tapatalk
  • Barrygsi
04 Dec 2013 12:04 #94514 by Barrygsi
Replied by Barrygsi on topic Re:2" lift advice
Im using 16"vitara wheels with 205r16 goodyear wrangler A/T tyres. No rubbing at all and its lifts the axle hieght up 1 1/2 inch over standard wheels.
  • Eders
04 Dec 2013 13:47 #94529 by Eders
Replied by Eders on topic 2" lift advice
It's a 2003 jimny and is totally standard at present, I have read on here that the transfer box mounts are worth upgrading would appreciate thoughts on this, I'm in Bristol - just want to ensure that I have solid motor for both aspects so I don't have bits flying of here and there. The car was mine ( well the wife's) was sold to father in law and now I'm buying back at the weekend so I know it's a peach engine wise and don't want to wreck it the first time I take it out
