Whistling Jimny
  • Flatfendweller
03 Dec 2013 08:42 #94382 by Flatfendweller
Whistling Jimny was created by Flatfendweller
First cold snap with the Jimny has thrown-up an interesting one because it whistles when cold. Not an engine whine as it only happens when a gear is engaged and it lasts less than a minute then stops. Definitely only happens when the temperature is around zero - other than that fine. Hope it's not an indicator of something expensive coming up!
Ideas anyone? :dry:
  • Stu stu
03 Dec 2013 11:13 #94400 by Stu stu
Replied by Stu stu on topic Whistling Jimny
The Christmas elf strapped a turbo to it while you were asleep ;)
  • Flatfendweller
03 Dec 2013 11:24 #94401 by Flatfendweller
Replied by Flatfendweller on topic Whistling Jimny
Oh that would be lovely. Do you think??
  • helijohn
03 Dec 2013 22:21 #94469 by helijohn
Replied by helijohn on topic Whistling Jimny
Clutch thrust bearing or if it is in the engine then water pump or alternator. Those are my suggestions.
  • ZookFastback
04 Dec 2013 03:13 #94484 by ZookFastback
Replied by ZookFastback on topic Whistling Jimny
:whistle:
04 Dec 2013 03:52 #94485 by kirkynut
Replied by kirkynut on topic Whistling Jimny
Could it be a bit of damp on the alternator & power steering belts? It could be a bearing in the alternator etc
Time to create page: 0.096 seconds
