Radio died
  • Jonnie
12 years 11 months ago #94320 by Jonnie
Radio died was created by Jonnie
Radio was working fine this morning but went off never to return when I started the car !
Have checked all the fuses in the fuse box located near the drivers right knee (after eventually finding the fuse box!)
Any ideas? Is there is another set of fuses? Is there an inline fuse? Was it an extraterrestrial pre-emptive EMP strike ?
Thoughts welcome.
  • little jimny
12 years 11 months ago #94335 by little jimny
Replied by little jimny on topic Radio died
Some headunits have their own fuse, either in the back of the unit itself or as an in-line fuse in it's wiring loom. Best bet would be to pop it out and get busy with a multimeter.
  • Jonnie
12 years 11 months ago #94361 by Jonnie
Replied by Jonnie on topic Radio died
Must admit you have the same thoughts as me. Will have to get some of the daft little keys to take the radio out. - not a standard radio.
Cheers
  • Stu stu
12 years 11 months ago #94364 by Stu stu
Replied by Stu stu on topic Radio died
check under the bonnet for a small fuse box? most cars have em there aswell not sure about the jimny, but normally near the battery.
  • Jonnie
12 years 11 months ago #94420 by Jonnie
Well
Checked more fuses ....... All ok
Searched high and low and found the radio removal tools so took it out and checked the fuse in the back of the radio ..... All ok
Faffed about with things and put it all back feeling non the wiser.
And now it works. !!!!!!!!
So quitting while ahead
Thanks for responses.
  • Dougall
12 years 11 months ago #94449 by Dougall
Replied by Dougall on topic Radio died
Mine is a bit temperamental (it's the newer style clarion unit) and sometimes refuses to switch on. It's a simple case of switching the engine off and on again, sometimes a couple of times before it works. Haven't found any problems with the wiring loom but for now the engine off/on trick appears to work.
Time to create page: 0.091 seconds
