Should these be removed
  • piprice
01 Dec 2013 15:25 #94144 by piprice
Should these be removed was created by piprice
Just pondering whilst doing the odd jobs to the jimny...
When I done the lift with the spacers i removed these...
The bump stop looking one is the rear and the smaller is off the front...
  • Stu stu
01 Dec 2013 15:41 #94147 by Stu stu
  • Reloaded
01 Dec 2013 16:41 #94156 by Reloaded
Replied by Reloaded on topic Should these be removed
piprice wrote: Just pondering whilst doing the odd jobs to the jimny...
They're just the rubber spring seats, mine got taken off on the blue Jimny when I fitted spacers.
  • piprice
01 Dec 2013 17:49 #94172 by piprice
Replied by piprice on topic Should these be removed
That's good then lol
Was rocking sideways whilst pulling steering wheel off and could here a little clunking...
There was no way the spacers would sit tidy with them on anyway!
  • Dave cc
01 Dec 2013 18:52 #94186 by Dave cc
Replied by Dave cc on topic Should these be removed
Ok to remove them if you are fitting spacers and the spacers are made of PU or somthing like that IE soft and compliant but if you are fitting lift spring then they should stay as they isolate the road springs from the body and stop nasty grinding noises.
  • iloveics
01 Dec 2013 19:29 #94189 by iloveics
Replied by iloveics on topic Should these be removed
yea loose them for spring blocks, but keep them for proper spring lift
Time to create page: 0.178 seconds
