snorkels
  • foggy
29 Nov 2013 16:17 #93791 by foggy
snorkels was created by foggy
Hi Forum Buddies,
Wondering if I could get some advice on snorkels please.
1. Are they worth fitting if you dont do serious off roading?
2. There seems to be a huge difference in price between different makes etc, I notice the jimny snorkel sold in the online shop here is much much cheaper than others. Are they as good etc etc?
3. Do you need anything else to go with the kit or can the snorkel go straight on?
Many thanks.
  • idiotmobil
29 Nov 2013 16:23 #93792 by idiotmobil
Replied by idiotmobil on topic snorkels
if you not offroading much and don't do any deep water then its going to be abit of a waste of money other than looking quite cool
  • jonesyba420
29 Nov 2013 16:27 - 29 Nov 2013 16:31 #93795 by jonesyba420
Replied by jonesyba420 on topic snorkels
the main question you need to ask yourself is this: am i planning on going into water that comes up above the bottom of the headlights?
anything deeper than the bottom of the headlights (which is probably still pushing your luck abit) and your in danger of the engine injesting water as the air intake is level with the headlights.
if you answer yes to the above question invest in a snorkel.
the one from the shop on here is probably the most common one people go for as its stylish and reasonably priced, i believe a Safari (probably the "best brand") snorkel is twice the price and does the same job!you can get cheaper ones but they are generally made of fiberglass which will shatter if you have a close encounter with a tree or such.
all you need to do is cut a large hole in the wing and some small holes to bolt it on quite straight forward i believe :dry:
also bare in mind that if going through water deeper than the centre of the wheel then axles, t-box and gearbox extended breathers are recomended.
Last edit: 29 Nov 2013 16:31 by jonesyba420.
  • piprice
29 Nov 2013 16:39 #93806 by piprice
Replied by piprice on topic snorkels
The sound over 3000rpm is nice too :D
  • jonesyba420
29 Nov 2013 16:45 #93810 by jonesyba420
if you want a better sound fit a performance air filter for £30 job done, or just drill a few holes in the exhaust :whistle:
  • tommyguns
29 Nov 2013 17:37 #93825 by tommyguns
Replied by tommyguns on topic snorkels
jonesyba420 wrote: or just drill a few holes in the exhaust :whistle:
haha amen to that! need to look into a new eggsause this christmas, might have to get a cherry bomb mind
Time to create page: 0.173 seconds
