Ora front recovery points help!
  • Wiltec17
12 years 11 months ago #93469 by Wiltec17
Ora front recovery points help! was created by Wiltec17
I'm laying under the jimny scratching my head. Has anyone got pictures of the bolt holes of there recovery points. Bit that's got me confused, the rear most bolt holes will require drilling through both chassis walls, where as the front is hollowed. Is this correct, if so the bolts provided seem to small to got through the chassis then bolt up with the washers. If someone could help me out I'd appreciate it.
  • rexthecat
12 years 11 months ago #93473 by rexthecat
Replied by rexthecat on topic Ora front recovery points help!
I just drilled through one from memory, was easy enough to get the nut in.
  • Wiltec17
12 years 11 months ago #93515 by Wiltec17
Replied by Wiltec17 on topic Ora front recovery points help!
rexthecat wrote: I just drilled through one from memory, was easy enough to get the nut in.
I was having a mare! Read your post then after a second look realised i could get my hand inside the chassis :pinch:
I got some pics so will post them up for future reference in case they might be useful for someone.
Thanks for your reply :)
Time to create page: 0.074 seconds
