suspension.
  • JuanGuillie
27 Nov 2013 11:00 #93423 by JuanGuillie
Replied by JuanGuillie on topic suspension.
jonesyba420 wrote: I wasnt planing on lifting it merely fitting longer shocks to give more droop keepimg the wheels on the ground for longer ;)
How much would it limit upwards travel fitting +2" shocks but keeping original springs?
I suppose id be asking to much for someone with a 2"lift to experiment for me :whistle:
would a set up like im thinking be at all beneficial offroad even if there is a loss of upwards travel?
Take care fitting this set-up, with 2" shocks and your standard springs :
these springs could pop out when you having a droop from a wheel on some axle-twisters !
Castor correction is not really needed with a 2" lift but you will have more tension on the bushes and they can worn out much faster.
  • jonesyba420
27 Nov 2013 11:28 #93425 by jonesyba420
Replied by jonesyba420 on topic suspension.
I understand a spring is not comparable to a shock it was just an easy way to explain my thinking :laugh:
I am aware of possible dislocation which is why id think of fittin spring clamps ;)
so caster correction bushes would be advised to avoid having to replace bushes all the time?
My jimny is my daily driver and used for green laning so a compromise for the 2 is what id want. Laning with idiotmobil I noticed the ride quality looked much better on his didnt look like he was getting bounced/jolted around so much.i believe he uses es1000's.
is the n2.0 more of an offroad specific shock over the es1000?
  • Yellostreak
27 Nov 2013 12:03 #93426 by Yellostreak
Replied by Yellostreak on topic suspension.
I heard that the rough country n2 have thinner shock bodies than the pro-comp es1000 and that at extreme angles the procomp can come into contact with springs, panard and such.. for that reason apart from ride the n2 is a better choice IMO
  • jonesyba420
27 Nov 2013 12:16 #93428 by jonesyba420
I heard that about the es9000 as they have a "fat body" didnt realise the es1000 suffered it aswell!! Are the n2.0's more comfortable (smoother ride quality) on and off road then the procomps?
  • Yellostreak
27 Nov 2013 12:30 #93429 by Yellostreak
only saying what I heard... cannot comment on ride quality as only have N's which are fine for what I do..
  • jonesyba420
27 Nov 2013 12:54 #93430 by jonesyba420
Can anyone verify this issue regarding the es1000's? How do the n2's ride on and off road compared to the stock suspension?
