cigarette lighter & clock
- vandenplas1
Thanks,Clive.
- jonesyba420
jonesyba420 wrote: I dont know if your center console is the same as my 2002 one but ill talk you through how mine comes out (off the top of my head anyway): remove the ashtray there is 3 screws 2 going into the bottom of the clock and 1 right at the back, *******there is 2 screws under the front panel at the buttom of the center console where the pointless tray thing is, and theres one in the middle at the top under the lip (if you have a aftermarket head unit take the front off and unclip the plastic surround then you should be able to see it,you may need to remove the headunit), from there the front of the center console should come off.......it should be pretty obvious from that point and bare in mind thats from memory so might be wrong,its along the right lines tho.hunt for screws
That one at the back is a right monster. Had to drill mine out and replace as it is a bolt more than a screw.
There are push fit lugs holding it in place.
****** As I recall there is a screw going upwards just ahead of the centre console and it goes up into the surround almost directly below the cig lighter. I nearly left mine off and I bet lots of people actually do cos it is a pain to reach. I used a stubby cross head to get at it.
