Battery flat as a pancake
  • piprice
12 years 11 months ago #93165 by piprice
Battery flat as a pancake was created by piprice
Cold weather is taking its toll, every morning jump leads are out, noticed the fluid was a bit
on the low side on the battery...
So topped it up with some water from the tumble dryer, sort of distilled.... Condensed if you like...
Read up a bit and it's a mixed review on using it, some say don't some say they've never had a problem!
Anyone tried this method before and did it work?
Otherwise dipping my pocket for a battery £15 second hand jobby. But will need to make it fit,
My mates vitara battery has took a dive too!
Not jumped it yet and took it for a blast as can't be arsed lol so don't know if it will work or not :D
  • Decalwizard
12 years 11 months ago #93185 by Decalwizard
Replied by Decalwizard on topic Battery flat as a pancake
Mine did exactly the same this morning
I used Deionised water (we use it at work) charged it up and its sort of ok. I think the plates are breaking down inside so its a new battery for me..
Tap water is the worst culprit for batteries as it contains so many chemicals that are react with the Pb plates. Tumble dryer or dehumidifier water should be fine.
DW
  • piprice
12 years 11 months ago #93188 by piprice
Replied by piprice on topic Battery flat as a pancake
Brilliant!
Are DW!! Fitted the mount - brilliant many thanks looks spot on! Much appreciated!
Anyway, aslong as I can get a few weeks with it not running flat after a good run I'll be fine, and then I can look at another battery!
Glad it's got the option to add acid / distilled water instead of just having a fooked battery with no other option but to get a new one!
Cold weather is the time for any faults to pop it's head up! Surprising what mild / warm weather hides!
Time to create page: 0.071 seconds
