Jimny sudden RPM raise problem
- MaxS
25 Nov 2013 09:49 #93074
by MaxS
Jimny sudden RPM raise problem was created by MaxS
Hi all, my 2005 M13A A/T jimny suddenly started raising revs.
on paring & neutral the car increases RPM up to 2000-2500, gas cable, throtal and the throtal spring looks fine, no check engine light, the only thing that seema to stop this is if i raise RPM up to 6000 for a sec and than th3 revs ge5 back to normal, i guess it some sensor on the throtal but i'm not sure.
In addition my car started drinking more fuel lately (before the revs problem accured) maybe both problems are connected?
Thank you all fir the asistance
25 Nov 2013 19:34 #93173
by Rhinoman
Replied by Rhinoman on topic Jimny sudden RPM raise problem
Your best bet is to pick up a cheap scan tool that can do live data and then check the sensor outputs. Check round for vacuum leaks and exhaust leaks too.
Time to create page: 0.076 seconds
