Best axles
  • Mister Stu
12 years 11 months ago - 12 years 11 months ago #93076 by Mister Stu
Best axles was created by Mister Stu
LR discovery axles as you'll have disc brakes all round and the option to run ashcroft goodies to uprate them, the ones for me will be a pair of 80 serise cruiser axles because they have lockers in as standard and are well over engineered but the only downside is the price and whether a pair can be found ;)
Last edit: 12 years 11 months ago by Mister Stu. Reason: wrong spelling
12 years 11 months ago #93077 by facade
Replied by facade on topic Best axles
The discovery 2 onwards used wheel bearings that cost even more than Suzuki, not sure why, knew a chap with a discovery 2 reckoned they were over £200 each.
Discovery 1/ RangeRover classic are standard Landrover but a bit wide for a jimny I think
  • steffan
12 years 11 months ago #93080 by steffan
Replied by steffan on topic Best axles
I don't think a 1.6 jimny will blow a land rover diff in a hurry considering they run 2.5 diesels which will have much more torque
  • TomDK
12 years 11 months ago #93083 by TomDK
Replied by TomDK on topic Best axles
LR axles are weak on Land Rovers. But as a jimny has way less power, and weighs half of what a Defender/Disco, it's nothing to worry about.
I would instead look at Samurai axles. They are 50 mm narrower than Jimny axles. But this can be fixed with a couple of spacers.
But with Samurai axles fitted, you can get relatively cheap H/D shafts from the US. And still keep the weight down. Unlike with LR/Toyota 80 series axles and the like.
  • steffan
12 years 11 months ago #93090 by steffan
That's the plan for mine once the engine and cage are done 24 spline rear disc one's tho
  • Dave cc
12 years 11 months ago #93094 by Dave cc
Replied by Dave cc on topic Best axles
Got G wagon under one of mine and Yota 70 series cruiser under the other TBH didn't really have to re new anything on the G wagon axles when I fitted them bar a couple of seals they are Dana style and one well made unit Yota 70 Cruiser axles are only about 1 inch wider than jimny axles just very well built mine has got ARBs each end but picked up a spare set few weeks back with a LSD for reasonable money ok so a LSD aint a locker but is a good starting point also all the bearings and seals are available from Roughtrax for the Yotas so that is a defo benefit Landrover Hmmmmmmmmmmmmm TBH I just couldn't :sick: :sick: :sick: :sick:
Time to create page: 0.108 seconds
