New tyres on which wheels?
  • Roccotune
24 Nov 2013 21:27 #93036 by Roccotune
New tyres on which wheels? was created by Roccotune
Hi guys, newby here! How do?
Missus has a 2002 jimny which is coming along nicely. Needs some shorter shocks for the back as no lift kit anymore and a few other bits and bobs but very fun car, I must say.
It needs 2 new tyres but I was wondering what you guys would recommend regarding which axel to put the new ones on?
I'm thinking rear wheels as they drive and put the older 2 on the front. I know normally people say front but...
Would normally do all 4 but not best just before Xmas.
What you think?
Cheers guys.
25 Nov 2013 04:48 #93062 by Lambert
Replied by Lambert on topic New tyres on which wheels?
The fronts do both the steering and most of the stopping so I would replace them first.
25 Nov 2013 09:05 - 25 Nov 2013 09:07 #93073 by facade
Replied by facade on topic New tyres on which wheels?
Just to confuse, I'd put them on the back.
If the front lets go you can likely go straight on into something, and the airbags work.
If the back lets go, (and a jimny is pretty tail happy at the best of times) you will spin round and you have no side airbags.
In The Olden Days, cars were made with more grip at the back by putting positive camber on the front wheels, and you couldn't put grippy radials on the front with slippery crossplies on the back.
Last edit: 25 Nov 2013 09:07 by facade.
25 Nov 2013 12:40 #93089 by kirkynut
Replied by kirkynut on topic New tyres on which wheels?
I wouldn't have any tyres on any car that were not up to the job. I would always want my best tyres on any car on the front.
You can drive around having a little less grip on the rear by not going so fast that the back end comes out in the wet. In snow & ice you'll be in 4wd anyway.
You can't drive around something entering your path making you do an emergency stop. All the weight transfers to the front and you want your best tyres there at that moment in order that you don't hit that person/car/horse/whatever...
We all have to slam the anchors on at some point, no matter how good a driver you are. At that moment in time, you want your best tyres on the front!
On my normal road cars I change tyres at about 2-3mm or more & never get near 1.6mm. On the Jimny, well when I'm less than 10mm I'll keep an eye on them!
  • Roccotune
25 Nov 2013 18:32 #93151 by Roccotune
Replied by Roccotune on topic Re:New tyres on which wheels?
Hmm some food for thought there guys! Normally I always make sure that the tyres are good. The ones currently on the back have 4 mm left so are ok but the front could well be the original bridge stones!
I did notice that the car is a bit slippery up front so, at least at first, due to ease I will try the front.
Looking forward to getting the jimny out in the green lanes as just back from a day leaning in the landrover :)
Now to choose a tyre!
Cheers guys.
26 Nov 2013 19:11 - 26 Nov 2013 19:15 #93332 by facade
I asked my brother, works at ATS.
Their recommendation, and that of the AA is to always put the best tyres on the back wheels.
Like I said, you want the front to let go before the back, which causes under-steer.
Once the back starts to overtake the front because the back tyres have less grip, you are in trouble, with the weight transfer to the front under braking there is less force on the back tyre to push it down through any surface water, so you need more tread to clear the water away.
Also, deeper treads are less likely to puncture, and a puncture on the front is more controllable than one at the back apparently.
(However, I've always swapped the unworn tyres from the back of my fwd cars to the front, and run with the 3/4 worn tyres on the back, then put new ones on the front when these wear down by 3/4)
Last edit: 26 Nov 2013 19:15 by facade.
